2000 S-10 Blazer check engine soon light
Old May 24, 2010 | 06:32 PM
Duggerrocks's Avatar
Duggerrocks is on a distinguished road
Default 2000 S-10 Blazer check engine soon light
it comes on periodically, and it spits an sputters arouns all the time. I have had the blazer on computers 10+ times and never got a single answer. Any of you experience this?
Old May 25, 2010 | 08:43 AM
Sisk's Avatar
** Moving to 2nd gen tech **
Please read all board descriptions, forum rules and stickies before posting to ensure you post in the correct board. The new member area is for introductions only.
Now some more info would be nice. By having it "on computers 10+ times" do you mean scanning it with a OBDII scanner? If so, it should be throwing codes if the check engine light is on, or at least have history codes it in showing why it was on. It could be many issues like the distributor, plugs and wires, MAF sensor, clogged catalytic convertor, etc. but again a scan with a scanner should give you some more insight. Once you have the codes it's throwing you can come back and check out the DTC (diagnostic trouble code) board for your answer on how to fix it.
givemesnow
Aug 1, 2011 02:54 PM
mxtmanx5
Sep 26, 2010 02:30 PM
OhioTrucker090
Aug 9, 2010 06:29 AM
Tony H
Dec 14, 2008 02:04 AM
45auto
Feb 24, 2005 09:30 PM
