2000 trailblazer transmission dilema
Old Jan 19, 2013 | 05:46 PM
Flatearthman's Avatar
Flatearthman is on a distinguished road
Default 2000 trailblazer transmission dilema
2000 4.3 automatic 4x4 4L60E trans 161,000 miles
drove to work fine, left work no overdrive or drive just first and second gear.
no codes, fluid is pink not burnt and level is where it should be just had a filter and fluid change at about 150.000 miles it has 162,000 on it now
when i changed the trans fluid and filter there wasn't much sludge or metal around the magnet.
truck has not been off roading i am the second owner and i bought it with 109,000 miles my comute is 98% highway.
any clues?
thanks in advance
Barrett
Old Jan 19, 2013 | 07:37 PM
blown262's Avatar
blown262 is on a distinguished road
I had a problem in a 97, where it would slip BAD in overdrive, but was fine in 3rd for a little while. 3rd started to slip almost as bad as overdrive, but 1st and second held with no problems at all. I researched a bit and found that 3rd and 4th share a clutch drum, but an overdrive band clamped down on the outside of the drum, causing the planetary gear to no longer gear down, thus creating OD. If I had to guess, there is something wrong with the control for 3rd gear, be it a stuck solenoid, or broken spring in the valve body. It doesn't sound like anything detrimental to the tranny, but I am absolutely no expert on this.
Old Apr 3, 2013 | 04:26 PM
alllw2000's Avatar
alllw2000 is on a distinguished road
Did you ever fix your problem and how much did it cost to repair? I have a 2000 rwd that has no reverse. Deciding to let a transmission shop fix or do it myself?
Old Apr 3, 2013 | 08:40 PM
Joshs4x4's Avatar
Joshs4x4 is on a distinguished road
Rebuild your looking at about 1,500 to 2,000 my sun shell we bad in mine it's no fun.
kiwiblazer
Jul 21, 2012 11:30 PM
Ugly_Monkey
Sep 24, 2010 01:11 PM
johnnyphive
Jun 21, 2010 04:26 AM
hotrod413
Sep 19, 2009 10:50 PM
StuckBlazer
May 26, 2007 04:50 PM
