2001 2wd blazer
Old Jan 29, 2014 | 02:44 PM
bigjamiemac's Avatar
bigjamiemac is on a distinguished road
Default 2001 2wd blazer
I can't find a answer anywhere so I registered in hopes someone can help me.. I was installing a radio the other day and I seen a few sparks.. I didn't think anything about it until I turned on the ignition and the radio didnt work, then I noticed the speedo, rpm, gas, p r d od 2 1, temp gauge, was all not working.. I found the radio fuse was blown so I replaced but not I can't seem to find why I can't get the above mentioned things to work again.. I ran out of gas last night cause I did not realize I was that low.. Please help if possible!!!
Old Jan 29, 2014 | 07:15 PM
vegie_2's Avatar
vegie_2 is on a distinguished road
go through your fuse block looking for a burned one, it could be under the hood or left side of dash
Old Jan 29, 2014 | 07:26 PM
spittybays
Guest
Posts: n/a
You need to pull the radio again and see exactly were your bare wired shorting
bob c
Oct 17, 2011 10:52 AM
theyammieguy
Lifting Tech
41
Sep 29, 2011 02:40 PM
Blazin01
Lifting Tech
Jan 19, 2009 01:43 AM
BLAZED821
Feb 2, 2008 09:13 PM
wormburnr
Nov 4, 2006 10:56 PM
