2001 4x4 woes
Old Aug 22, 2006 | 01:04 AM
jschurch's Avatar
jschurch is an unknown quantity at this point
Default 2001 4x4 woes
I have a 2001 4x4. When I try to switch in 4lo, the light blinks and CONTINUES to blink. 4lo works fine. The 4hi light even continues to blink after I have shut the truck off and restart it. Also, the button that releases the rear window that is located on the tailgate doesnt work, but the button inside the truck does.
Old Aug 23, 2006 | 10:30 AM
Dory's Avatar
Retired Super Moderator
Dory is a jewel in the roughDory is a jewel in the roughDory is a jewel in the rough
Default RE: 2001 4x4 woes
the 4wd thing could be a bad encoder motor.... or just the buttons are bad. as for the rear window hatch, i'm not too sure what is needed on those yet, dont have enough info on them.
Old Aug 23, 2006 | 04:47 PM
ZX9er's Avatar
ZX9er is an unknown quantity at this point
I am looking at a 2000 Blazer with the same 4x4 problem. 4lo works fine but when you push the 4 hi button it just blinks and 4x4 does not kick in. Any suggestions? Should I buy this truck since it's really cheap and hope this is an easy fix?
Old Aug 24, 2006 | 08:30 PM
4lowlife's Avatar
the transfer case control module (TCCM) may have dumped. Mine quit a while back and had to replace it. Quite pricey
Old Oct 26, 2007 | 02:52 PM
Skier1's Avatar
Skier1 is an unknown quantity at this point
How difficult was it to change out the TCCM. I haven't really looked into the process or under the car yet to see where it's located, but I am needing to change out mine. Thanks.
Old Oct 26, 2007 | 06:34 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
The TCCM on a 2002 is behind the right hand kick-panel, but how can you possibly know you need to replace it if you don't know where it is? You need to access it to acurately diagnose it. If you are having the same problem as listed above, ground pin # 13 of your DLC and turn the ignition on....then count how many times the indicators flash on the 4x4 switch..(this does not work if you have a 4-button switch with AUTO 4wd..only do this if you have a 3-button switch) the lights will flash each stored code 3 times before moving on to the next code. After you retrieve the codes, disconnect the negative battery cable for 5 minutes then reconnect it...it should clear the codes and start working again. Repost with your codes. It will be one or more of 4 different codes 1,2,3 or 4...just count the number of times it flashes between short pauses...it will flash each code 3 times with a short pause between each one and then a long pause and it will move to the next stored code if there is another one.
Old Oct 26, 2007 | 07:50 PM
Burlisonm's Avatar
Burlisonm is an unknown quantity at this point
When it is blinking is it in gear, neutral or in park mine won't go into 4lo without it being in neutral, just a sugg.
Old Oct 28, 2007 | 08:08 AM
quinnman105's Avatar
quinnman105 is an unknown quantity at this point
I was going to change out my 4x4 buttons. I am having the same problem. I went to Autozone.com and found it on their website. You may also want to call the dealer or a local garage and have check oit out for you.
Hope this helps you out
Kevin From Shelton, CT
Quinnman105
my1997blazer
Oct 20, 2013 01:44 PM
trical
Oct 18, 2013 08:50 PM
TomSB
Aug 19, 2006 10:40 PM
robert8868
Aug 18, 2006 12:22 PM
dundydotcom
Jul 8, 2006 05:07 PM
