2001 Blazer & 3 Fuel Pumps
Old Sep 29, 2013 | 10:59 AM
Firefly's Avatar
Firefly is on a distinguished road
Default 2001 Blazer & 3 Fuel Pumps
Hi all, back in June after 5 years I had a fuel pump failure. After 2 weeks from an aftermarket pump from mechanic, another failure. 1 month after that, another failure & now 2 months from that, another failure. I believe the last pump installed was a Delphi and all other were cheap after markets.
I noticed that the ground to the filler neck was disconnected. Questions are is Delphi a good brand or should I go right to dealer at this point?
Also would a faulty ground to or from the pump cause these failures? The mechanic tells me that each time this has happened it is a burnt out pump.
Really at a loss after today's failure.
Thanks.
Old Sep 29, 2013 | 11:14 AM
3 pumps in 4 months indicates a poor pump ground, it will cause premature failure every time, guaranteed. The ground wire on the filler neck is NOT the ground for the fuel pump. The fuel pump ground is located in a different place depending on 2 door and 4 door. Resistance and voltage drop, both need to be checked at the pump module connector. Whenever the pump is replaced, it's a good idea to run a new ground wire from the module connector directly to a good, clean body ground. This will avoid what you're experiencing. Delphi and AC Delco are the only recommended brands for pumps on these vehicles, but a poor ground will destroy them as well.
Old Sep 29, 2013 | 11:32 AM
Firefly's Avatar
Captain, thank you. I think this is the problem too. I will speak to mechanic tomorrow and tell him to run a new ground. I also will tell him I want a AC Delco.
Old Sep 29, 2013 | 11:33 AM
Firefly's Avatar
Oh, and my truck is the 4 door. Any idea where the ground may be?
Old Sep 29, 2013 | 11:58 AM
2001 Blazer: From the fuel pump module, the ground wire goes to a splice pack, (along with 4 other ground wires) behind the rear bumper. From the splice pack it goes to the extreme left rear corner of the frame, on top of the frame rail, (not easily visible, but it's there). At the module connector there are two black wires: Solder those two together along with a third wire. Run the third wire to a good body ground. Use 60/40 lead/tin rosin core solder and heat shrink tubing to insulate the connection.
kpmink
Nov 12, 2008 09:05 AM
maki3242@gmail.com
Jul 12, 2008 12:07 AM
punx.inc
13
Jan 17, 2008 08:04 PM
azc4
Dec 18, 2007 07:13 PM
LeftBehindGadgets
Dec 13, 2006 08:20 PM
