2002 blazer starts and immediately dies
Old May 18, 2025 | 02:17 PM
  #21
GeorgeLG's Avatar
That seems to be the spider of choice these days, good luck.
George
Old May 18, 2025 | 03:36 PM
  #22
SteveK02blazer's Avatar
SteveK02blazer is on a distinguished road
George
any thoughts on the bracket
Old May 18, 2025 | 04:04 PM
  #23
I believe that GM recommends a new bracket, but many have simply dropped the upgraded MFI spider into the older SCFI bracket without any issues, myself included on my old 2000 Bravada.
Old May 20, 2025 | 10:55 AM
  #24
Default Update
Thanks for that. I' got the new spider
in a new bracket. Pressures are now within spec, but she still starts and dies. So I will try the security relearn procedure. Then also check the ground g 117 as i did replace the brake booster and it is over on that side.
Old May 20, 2025 | 06:39 PM
  #25
Default Pass lock attempt.
Well I tried the security relearn. Attempt to start. Then leave the Ignition on for 11 minutes.. somewhere in there, the security light is supposed to stop blinking. It never does it just keeps blinking. Tried it several times.
Old May 21, 2025 | 06:37 AM
  #26
Default Security update
I decided to do it while sitting in the car this time. It was too hot yesterday. So with me in the car. Try to start. Starts and dies leave key on. Light stays solid for a second goes out then comes back on solid. Waited eleven minutes state solid the entire time. Anybody with any insight?I suppose I can try it three times in a row.
If I try to do it, you know, like with the door open and leave the Ignition on. So I don't have to sit in it. It'll just blink and not turn off.
Old May 21, 2025 | 08:38 PM
  #27
GeorgeLG's Avatar
Make sure you are doing this:
https://blazerforum.com/forum/new-me...curity-105785/
George
Old May 27, 2025 | 02:44 PM
  #28
Default Security relearn update
Security relearn
Yeah I tried it three times. Same result. Turn ignition on.the security light stays on for a quick second and then goes off. I try to start the car. It starts and dies..I leave the ignition on. Security light immediately goes out for a quick second, and then comes on solid It. And never goes out during the ten minutes. I tried it three times in a row, same result.
Old Jun 2, 2025 | 06:26 PM
  #29
Default Where to go next
Well, I'm trying to hang in there. Butt still no luck . She still starts and immediately dies. If I disconnect the coil wire and yeah, crank for a bit and she'll run a couple seconds longer before she dies. So i'm pretty sure then the security is shutting the pump off. I've tried to relearn, but as I noted, the light stays solid. Try to start. Light goes off then comes on solid with ignition on. Never blinks.
The only time it blanks.Is it like if I have a door or the hatch open.
Old Jun 2, 2025 | 07:19 PM
  #30
int3414's Avatar
int3414 will become famous soon enough
maybe replace the ignition switch,since youall talked about the security passlock ,ive done that job before (dont rember why),but it cured my problem
