2002 Chevy Blazer Oil Leak in Front of Car
Old Oct 7, 2013 | 04:27 PM
ThatGirl1971's Avatar
ThatGirl1971 is on a distinguished road
Default 2002 Chevy Blazer Oil Leak in Front of Car
Hi all!
Two weeks ago, I noticed a little oil under the front of my car. I looked underneath and saw that the oil filter door was open and hanging down. I didn't see any leaks from there so I shut the filter door. Nothing since.
Today I noticed a bigger oil spot, and I went out and looked underneath again. This time, the oil filter door was closed. However, towards the back of that door, it looked like the plastic was bowed (for lack of better words), and I saw the oil dripping from there. From different things I read it could be hoses...with the one set being easier to replace than the other. Also, for the past two years, I've been losing coolant, which I also read is not good news, but I've had no engine issues regarding this.
I hope someone can point me in the right direction. I'm a full-time student majoring in IT, so mechanics are not my specialty.
Thank you in advance!
Joanie
Old Oct 7, 2013 | 05:23 PM
chris015's Avatar
well,you need to pull off that plastic covers stuff. then head up to the car wash and pressure wash it down to clean it up. then run it around town for a few minutes and go home. then grab a flashlight and find the leak. it'll be fresh since u washed it. then grab us a pic.
Old Oct 7, 2013 | 05:31 PM
Okay, Chris, it's getting dark here now, so I'll do it tomorrow and get a picture. Thank you!
Old Oct 8, 2013 | 11:24 AM
LannyL81's Avatar
The plastic shield comes off by removing 6 15mm bolts; the shield then just drops down. No problem leaving it off while you find the oil leak source unless going off road.
Common problem with the '02 is the front two oil pan bolts come loose and fall out. Requires a U joint adapter on the end of an extension to get to the bolts, but not difficult to either tighten or replace the bolts. Just do not get over tighten the bolts or the gasket will squish out as I do not know if there are washers imbedded in to the oil plan gasket that prevents this or not.
fletch125
Dec 24, 2014 12:53 PM
JayTalbott
Aug 4, 2014 12:15 PM
ssmith0386
Nov 17, 2013 08:02 AM
iamchevyman5
Nov 23, 2011 06:14 PM
TAZ454
Jan 28, 2008 10:11 AM
