2002 chevy s10-blazer dogleg with rust spots
Old 09-22-2010, 12:01 PM
BuddyS's Avatar
BuddyS is on a distinguished road
Default 2002 chevy s10-blazer dogleg with rust spots
Hi, I have a 2002 chevy s10-blazer 4-door with rust spots/bubbles in paint on the driver side dogleg (quarter panel in front of rear wheel). Does anyone else have this and do you know if it is coming from the inner side of the panel. Is this a common problem for this body? I know the 2-door realy had this problem.
Any and all help would be great, pictures of other rust on dogleg would help to see if it looks like mine
Thanks
Old 09-22-2010, 12:03 PM
High_Speed's Avatar
High_Speed is on a distinguished road
I don't think there's one peice of metal under my 2001 LT 4door that isn't rusted.
Old 09-22-2010, 06:54 PM
BuddyS's Avatar
Well I took off the inner interior trim and found a good size hole and was able to see into the cavity of the dogleg, It looks as if GM used an expandable foam inside of it. Well I than got a tube and pored some rust destroyer into it, the stuff started dripping out the pinch weld seem inside the wheel well. That should hold off the rust I hope. Now I will polyurthane the seems inside the wheel well and cover that with undercoat to keep out the water.
What to you guys think?
I hope this helps as I caught this earlly.
Chic_Bowdrie
03-31-2012 08:47 AM
BuddyS
09-23-2010 07:12 AM
a_tack
02-03-2008 08:30 PM
bgillette78
04-14-2007 07:54 PM
offroadin00blazer
09-15-2006 01:08 AM
Quick Reply: 2002 chevy s10-blazer dogleg with rust spots
