2002 S10 Key Ignition Housing
Old Aug 11, 2018 | 05:56 PM
Kevin A. Phillips's Avatar
Kevin A. Phillips is on a distinguished road
Default 2002 S10 Key Ignition Housing
Hey,
I got the steering wheel pulled and began to remove the ignition housing, but the cable at the underside is stuck. I know that you're supposed to move the housing back to the off position using a large screwdriver down inside the cylinder housing, but this is the reason why I'm replacing the entire housing as it is.
The cylinder is stuck within the housing, will not turn in either direction and will not be released in using the hole at the top that you normally would remove the cylinder with. I'm stuck, I can't remove the cable because I can't turn the cylinder to the OFF position.....
What do I do?
Kevin A. Phillips
Aug 6, 2018 08:47 AM
Dobe Rottie Gang
Aug 30, 2013 11:14 AM
MetalMan390
Jun 8, 2010 02:27 PM
97ssblazer
Sep 2, 2009 01:08 AM
rockettme
Aug 13, 2007 12:42 PM
