2004 4x4 4 door blazer problems
George
yup. all 4 doors. I can hear something engage but i guess it just does not lock properly. I can open all 4 doors and they are supposed to be locked.
Your remote (lets say) is transmitting and the truck is receiving the signal because you can hear the door lock motors engage and then all 4 doors do not lock correctly?
If I have this right then you most likely have a wiring, connector, power, ground or relay problem because your lock motors do not completely lock the doors and its virtually impossible for all 4/5 motors to be failing at the same time. Let me know if you need help debugging but you may be in for a project on this one.
George
George
George
George
That's the strike plate. The original most likely got damaged from the sagging door being slammed shut. The fix is the hinge pin bushing replacement.
After an electronic lock command is the manual slider on the inside of the door all the way over to the lock position? If not can you finish the process by manually moving that slider?
George
George
George
George
Post #9 in this thread.
