2004 Chevy blazer LS want to improve mpg
Old Apr 23, 2017 | 07:48 PM
newguy's Avatar
Basically, these are trucks, they wont get good gas mileage
Old Apr 23, 2017 | 07:56 PM
Irishpride13's Avatar
Irishpride13 is on a distinguished road
I'm not bitching about the gas mileage I want to truck since I was 16
Known the entire time what comes with it
I think the better question I should've asked how to maintain its current gas mileage and make sure it doesn't go down
Outside of its normal maintenance
Old Apr 23, 2017 | 08:12 PM
chevyriders's Avatar
New plugs and wires regularly(run nice quality ones)a k&n air filter(maintain the filter by washing it and oiling it as it gets dirty) keep your throttle body nice and clean. New fuel filter wouldn't hurt either. You could run some Sea-foam through your fuel system once a year to help keep injectors clean... Pretty much keeping up on your regular maintenance is the key
Old Apr 23, 2017 | 08:29 PM
My ex street racer friend said add a turbo small one
Old Apr 24, 2017 | 07:38 AM
awesomeamerican1's Avatar
awesomeamerican1 is on a distinguished road
Originally Posted by newguy
Keep injectors clean, clean oil, newer o2sensors, airfilter, tires inflated. Or buy a prius
prius hahahaha that's priceless
Like newguy said basic maintenance makes all the difference. Where I noticed the most change was with all new o2 sensors. Should have seen the ones I took out of my truck, I don't think I had any at all...hahaha I also run the lucas injector cleaner every other tank and now I'm up to 20 mpg. All going to go down hill when I fit these 37s on though...
Old Apr 24, 2017 | 08:58 AM
Tajohns34's Avatar
Make sure your your fuel filter is clean, or just put a new AC Delco on in since they are cheap. You could also switch to an electric fan.
Old Apr 24, 2017 | 08:23 PM
TMM217's Avatar
TMM217 is on a distinguished road
Keep it at 60mph or below. What does everyone think of those vortex generators theyre using on the big rigs?
Old May 14, 2017 | 09:33 AM
jimspahr@msn.com's Avatar
Here are some steps for incremental MPG increases: tune up engine with AC Delco ignition parts; change engine oil to full synthetic oil; increase tire pressure 2 to 4 lb.s PSI; drive and brake carefully-- iow don't drive like a teenager; remove unnecessary weight from vehicle; if you have large, knobby tires, buy stock sized 'highway' tires; get an alignment; and make sure none of the brakes and the parking brake is working properly and not causing brake drag.
97Bravada
Performance & Brainstorming
26
Apr 29, 2011 05:31 PM
DdayK5
13
Jan 31, 2009 09:55 PM
nitehawk3600
Apr 10, 2008 04:34 PM
Jrice791
Engine & Internal
66
Mar 28, 2008 06:39 PM
zachwagner
Suspension Tech
Dec 11, 2006 08:01 PM
