2005 ZR2 issues after body lift
Old Dec 4, 2017 | 04:06 PM
studentone35's Avatar
studentone35 is on a distinguished road
Default 2005 ZR2 issues after body lift
Looking for some help, just installed a 2" zones body lift on a 2005 ZR2 blazer and now my fuel pump and tag lights will not work. I cleaned the frame to bare metal for both the fuel pump ground wire located at the rear of the blazer and the ground extension at the front passenger side for the negative battery cable. I checked the fuel pump relay fuse by swapping it with the horn fuse so I know that's not the issue. any help would be greatly appreciated.
Old Dec 4, 2017 | 05:56 PM
El_Beautor's Avatar
If all your fuses are good, my guess is that you're on the right track with checking grounds. Look through the wiring diagrams in the Tech section, and check each ground pack.
Old Dec 4, 2017 | 07:13 PM
You might have to create dedicated ground wires instead of relying on the mounting bolts if the body lift "broke" the ground path for some of these items.
Old Dec 5, 2017 | 09:32 AM
Do the tag lights share the same ground wire that the fuel pump uses?
Thanks
Old Dec 5, 2017 | 10:16 AM
Thanks
Maybe someone has a wiring diagram?
blue_zr2
Lifting Tech
Apr 21, 2011 05:51 AM
HcHawks09
Suspension Tech
13
Feb 17, 2011 11:18 PM
Blazer_boy
Lifting Tech
Dec 28, 2010 08:03 PM
SmoyMoose
Mar 30, 2010 07:41 AM
SmoyMoose
Lifting Tech
Mar 11, 2010 09:57 PM
