2WD to 4WD shift problems
Old Jul 25, 2012 | 04:43 PM
tpolzin's Avatar
tpolzin is on a distinguished road
Default 2WD to 4WD shift problems
A 1999 Blazer 4 door with a three button 4WD.
Won't shift after the 2WD/4WD shift buttons have been cycled twice. If in 4WD, and I push the 2WD button, the 2WD light flashes once and the TCCM relay clicks. If I unplug the TCCM, everything works perfectly for exactly two cycles, then does the click and flash with no shift. Reading the DTC code for the TCCM I get fault code 3.
I had a spare transfer case, so I swapped the vacuum switch and the encoder motor with no change. Vacuum lines are all good.
I'm thinking there is a fault with the TCCM.
Tim
jordanroch
Nov 6, 2013 09:53 AM
CB160
Jul 14, 2010 11:27 PM
kzikyoshi
Nov 3, 2009 08:03 PM
EnyChevyUK
Apr 22, 2009 12:30 AM
Blahman20
Nov 3, 2008 09:45 PM
