4.3 vortec coolent leak
I have a 95 blazer 4.3 vortec I notice that I was smelling coolant in truck and no heat or defrost and the temp hand was at half way and truck have not did that since i had it so I thought it was about to over heat. So I changed heater core. Then I replace water pump and thermostat. Get everything back together and now i got a leak. Everyone said LIM gasket so I replace that and I still have leak. I notice one day water was leaking behind power steering pump. I don't know where leak is at. Its not leaking where I have replace parts and gasket at.....any idea really confused
thanks in advance
thanks in advance
It sounds like it is still your LIM to me. Did you use the new Felpro gaskets (I don't have the part number handy)? Did you torque it down correctly?
It not the LIM you may be looking at a head gasket.
I changed the lower intake gasket by fel-pro and torqued it back down at 35 lbs...........I am really lost i drove to store today temp guage hand went to half and store not even 5 min away. I went in the store truck was leaking, when I came out of store and truck had stop leaking and i was only in store less than 2 min..............
Beera
17
Sep 3, 2012 03:15 PM
redskins1
27
Mar 12, 2010 06:04 PM
