4.3 vortec coolent leak
Old Mar 21, 2012 | 03:26 PM
shawtydee03's Avatar
shawtydee03 is on a distinguished road
Unhappy 4.3 vortec coolent leak
I have a 95 blazer 4.3 vortec I notice that I was smelling coolant in truck and no heat or defrost and the temp hand was at half way and truck have not did that since i had it so I thought it was about to over heat. So I changed heater core. Then I replace water pump and thermostat. Get everything back together and now i got a leak. Everyone said LIM gasket so I replace that and I still have leak. I notice one day water was leaking behind power steering pump. I don't know where leak is at. Its not leaking where I have replace parts and gasket at.....any idea really confused
thanks in advance
Old Mar 21, 2012 | 04:36 PM
grizzstang's Avatar
grizzstang is on a distinguished road
It sounds like it is still your LIM to me. Did you use the new Felpro gaskets (I don't have the part number handy)? Did you torque it down correctly?
It not the LIM you may be looking at a head gasket.
Old Mar 27, 2012 | 06:19 PM
I changed the lower intake gasket by fel-pro and torqued it back down at 35 lbs...........I am really lost i drove to store today temp guage hand went to half and store not even 5 min away. I went in the store truck was leaking, when I came out of store and truck had stop leaking and i was only in store less than 2 min..............
Old Mar 27, 2012 | 07:54 PM
mjt's Avatar
mjt
mjt is on a distinguished road
Maybe its a head gasket. Why dont you try having it pressure checked. With the engine off it might be easier to tell where its coming from
Old Mar 27, 2012 | 08:45 PM
vegie_2's Avatar
vegie_2 is on a distinguished road
I had a leak and did the intake with the steel felpro gaskets still leaked
I found out a bolt was missing in water pump mounting bolts could be your problem too! since you said its by power steering pump
Beera
17
Sep 3, 2012 03:15 PM
redskins1
27
Mar 12, 2010 06:04 PM
lry040
Apr 15, 2008 06:25 PM
eelding
Jun 23, 2007 06:15 PM
eelding
May 10, 2007 09:54 PM
