4.3L Fuel Lines info
I have a 96 4dr Blazer LT 4.3L and need to know about fuel line removal at the back of the LIM by the firewall. The fuel lines each have 2 nuts, one for holding the connection still (on the bracket) and one for turning to loosen the connection.
Is there a simple tool to get at these connections for removing? Could I use a couple of stubby wrenches and what sizes would I need? I have one set of fuel line rings from a Fel-Pro MS980002T LIM gasket kit, do these fit right in or are there any other washers that I would need to retain from the existing connection?
Do yourself a HUGE favor: Using a socket & ratchet on the crankshaft bolt, manually rotate the crankshaft clockwise until the distributor rotor is aligned with the "6" on the distributor housing BEFORE you remove the distributor. Then, DON'T bump the starter or move the crankshaft until the distributor is reinstalled back in the engine.
1996 blazer fuel line removal
My 1996 uses a 5/8" for the small nut on the line and a 3/4" nut fixed to the mount at the back of the LIM, by the firewall. I purchased a set of SAE stubby wrenches that had both sizes for $20 at AA.
sporty982000
08-24-2014 07:45 PM
skid9832004
06-05-2011 01:38 PM
dj00140
04-13-2011 10:48 PM
