4 door gas tank (non fuel pump) hose connectors
Old Apr 21, 2022 | 09:13 PM
Busher56's Avatar
Busher56 is on a distinguished road
Default 4 door gas tank (non fuel pump) hose connectors
2001 4 door blazer gas tank hose connectors. On the same end of the gas tank as the fuel pump there are two more hose connectors. One larger diameter hose and one smaller diameter hose. They both use a snap on type of connector similar to the three hoses on fuel pump but they don’t have the piece on them that slide over the plastic nipple before you snap on hose. Is this normal for those two hoses or am I missing those pieces. Wish I knew correct name of the fittings but not a mechanic.
Old Apr 22, 2022 | 04:53 AM
perumotors1369's Avatar
perumotors1369 is on a distinguished road
you 'squeeze' these hoses at the correct spots(2) and pull them off...you are not missing anything...patience..they will slide on easy when lined up properly..lube them with something when putting back on..that will help you..
oregonchevy
Jun 21, 2018 08:44 PM
LannyL81
Oct 21, 2017 08:13 AM
Phil Underhill
Jan 21, 2017 06:39 AM
rastoma
Mar 27, 2012 07:49 AM
ratwell
Dec 16, 2007 09:50 AM
