4-HI acting up when turning sharply
2004 3 button 4WD acting like tires are scraping on something, but they are not. Its kind of a chattering when turning the wheels sharply left or right in 4-HI. No symptoms in 2-HI and I forget about it until I put it in 4-HI. Then it drives fine until I have to turn sharply or turn while backing up.
Then the front wheels chatter like crazy. 4 DR Blazer WGN 2004 V6 4.3 SEFI.
think of it this way... in 4 hi you have 2 sets of wheels getting power....
SO when you turn sharply on something with crazy traction (like black top) you have 2 wheels pulling you where they are pointed (front) and 2 wheels pushing you forward (rear) this will cause a kind of chugging, clipping motion.... it's normal.
turning sharply (or even more than gently) in 4wd on pavement or other high traction surfaces will cause a bit of strain and a rough feel. it's normal...
Yep, as stated, this is completely normal. You definitely should not be trying to make this happen though. The drivetrain is binding up because the transfer case links the front and rear driveshafts together, driving them both at the same speed. When you turn, all 4 wheels take different paths. This causes drivetrain bind as the driveshafts are trying to turn at different speeds and causes the symptoms you describe.
