4L60E engine load by vacuum line???
Old Sep 9, 2012 | 10:05 AM
monette999's Avatar
monette999 is on a distinguished road
Default 4L60E engine load by vacuum line???
Does the 97 S10 blazer 4L60E transmission detects the engine load by a vacumm line? This question is related to hard shifting under full loead.
I have heard that on other automatic concepts they detect the engine load by a vacuum line.
Hope you can explain this to me.
BR
Bob
File Type: pdf
Old Sep 9, 2012 | 01:37 PM
viper1ex19's Avatar
viper1ex19 is on a distinguished road
NO,
The 4L60E is electronic controlled. The ONLY Vaccuum Lines would be for the Transfer Case Shift Module on the 4X4 Models.
· It has a Speed Sensor that does more than just tell you how fast you’re going.
· It has Pressure Sensors inside the transmission that determines how much load is on it by the amount of Fluid Pressure. That signal is sent to the Vehicle Control Module (VCM) located behind the lower right hand kick panel on the passenger side floorboard area.
· That signal is also sent to the ECM where it makes engine adjustment accordingly
Your Speed Sensor can have an affect on your Speedometer (obviously), It will prevent your transmission from shifting into higher gears (3rd-4th usually) it can affect your Brake Lights, your Cruise Control, and I’m sure a couple other things.
I went through all of this on my 97 S-10 here a while back so I can tell you all I did to get mine working if you have problems.
Old Sep 11, 2012 | 10:46 AM
monette999's Avatar
Thank you buddy
Old Sep 11, 2012 | 12:39 PM
chris015's Avatar
Lol you must be thinking about the old 350 and 400 trannys back in the day.
dj00140
22
Nov 4, 2015 05:03 AM
etowntom
Sep 7, 2010 08:16 PM
MAScott
Dec 6, 2009 08:03 PM
an240172
Sep 7, 2009 02:58 AM
95blazer8620
Oct 19, 2007 01:26 PM
