4wd fuse 98
4wd fuse 98
hi my 4wd is messing up, randomly switching in and out of all the different 4 wheel drives, i heard u can take out the 4wd fuse so it wont work. took out the fuse but the liitle lights for 4wd still comes on. maybe the lights are a different fuse. idk. i just want to cut power to 4wd. gotta get to work
I took the actual 4wd fuse out but now I don't have a gas reading or temp or the little green square to tell me what gear I'm in. Runs fine but I need that stuff. I was thinking maybe unplug the little box behind the right kick panel but I'm scared to fry something. My 4wd started actingfunmy after I gave sum1 a jump so my uncle pulled a differential off the bottom. Ran good for about a year in 2wd but the dash said 4hi. Then one day it started jumping all weird on take off and eventually wouldn't give gas to the engine, just rev. I got it to go into 2hi when Ihad the key on and played with 4wd buttons then randomly locked into 4lo and started to grind randomly shifting gears from park. I just pulled the fuse runs good but I'm missing gauges
AustinBlazer
06-04-2013 10:35 AM
champ186dc
01-09-2010 10:34 AM
gERgMan
05-16-2008 10:12 AM
