4wd issues
i think you can only do that with obd1
you gotta be a little bit more descriptive with your problem, describe what happens when you press each of those buttons
it could be any of the following......
bad dash switch
bad tccm
bad encoder motor
bad dash switch
bad tccm
bad encoder motor
well a good way to start is by pulling the codes
it will definitely lead you to the problem
Most shops will pull your codes for free (with the thought that you are going to give them money to fix the problem) so just take it in and get the codes read.
daemeon2
01-06-2013 04:06 PM
99slobra
01-03-2013 05:02 PM
cruukedeye
06-04-2011 06:49 PM
