4wd lockup, problem.
Old Sep 27, 2011 | 04:45 AM
Tangvik1's Avatar
Tangvik1 is on a distinguished road
Default 4wd lockup, problem.
Hello! I have a 95 4wd lt blazer with the 3 button 4wd. When i drive the car off-road and get one front-wheel in the air, I'm not going anywhere. The 4wd works, but should the front axle lock up and help me out? This question might have been brought up earlyer, but i couldn't find it by searching. Sorry about the bad english, I'm from Norway.. Thanks guys!
Old Sep 27, 2011 | 09:01 AM
Tommy G's Avatar
Tommy G is on a distinguished road
No front differential is open. Without traction on one wheel, the other will not get power transferred to it. You would have to install an aftermarket locker or limited slip to get power to both front wheels.
Old Sep 27, 2011 | 09:13 AM
To result in no forward motion, you would also have to be spinning a rear wheel at the same time. When locked in 4wd, the transfer case delivers equal power to both the front & rear axles. With open diffs both front & rear, it is pretty easy to get one wheel on each axle spinning like crazy resulting in no movement.
A locker in the aluminum front axle housing on these trucks isn't really a great idea.
Old Sep 27, 2011 | 12:35 PM
Tangvik1's Avatar
Thank you for the quick answers. Thats just the way it is then, i'll have to work up some more speed the next time i think the rear end locks up tough, at least on the road straight ahead it does.. is there anyway to make the rear end diff-brake more efficent, by using a special type of oil or something? mabye not a good idea, as im using the blazer as a daily driver?
warthogdriver
Jan 25, 2011 05:07 PM
Todd525
Nov 30, 2008 05:54 PM
Always Broke
Nov 18, 2008 10:10 PM
pbrew
May 2, 2008 12:09 AM
myblackblazer
Apr 25, 2008 08:46 PM
