4wd wont engage please help 1997 Blazer
Old May 30, 2012 | 11:48 AM
xillzxnickx's Avatar
xillzxnickx is an unknown quantity at this point
Default 4wd wont engage please help 1997 Blazer
i have replaced the vacuum switch on t case the cable was slightly froozen and i broke it lose and the thing that pulls the cable works fine. the front drive shaft spins but wont engage if you manually pull the cable in makes a slight click but not engaged
the car use to always try to be engaging the 4wd because the vacuum switch ball was stuck up but even with the vacuum thing always pulling the cable it wasnt in 4wd
this is a 1997 blazer 2 door 5 speed
Old May 30, 2012 | 02:57 PM
If the transfer case does not engage the front driveshaft, there could be a problem with the TCCM or encoder motor. Engine at idle, trans in neutral, 4WD selected: The vacuum line at the axle actuator under the battery must have manifold vacuum. If it does, make sure the cable pulls in about 1/2" to 3/4". If the cable pulls in, the right front wheel should lock in. If not, the clutch mechanism in the axle tube needs attention.
camaro6102
Sep 15, 2013 11:21 PM
gibson308
Sep 18, 2011 04:36 PM
maty98blazer
Feb 16, 2011 01:25 PM
breakyadown89
Dec 9, 2009 06:34 PM
catruck
Apr 6, 2008 12:45 AM
