4x4
Old Sep 7, 2011 | 12:39 AM
1997 Gmc Jimmy's Avatar
1997 Gmc Jimmy is on a distinguished road
Default 4x4
I have a 1997 gmc jimmy and when i try to put it in 4 wheel sometimes the light just blinks and does nothing and sometimes it pops tons of fuses now it only goes in 4 wheel lo. any Help or Ideas
Old Sep 7, 2011 | 06:43 AM
HigherPower's Avatar
HigherPower is an unknown quantity at this point
I thought I had an issue this week with mine not engaging properly.
Try these: https://blazerforum.com/forum/tech-a...2hi-4hi-40695/
And check this blog out I thought the write up was good info!
'03 Chevy Blazer -- where's my 4 wheel drive? (UPDATED) | KyleStubbins.com
Hopefully you can track it down and it's an easy fix.
Old Sep 7, 2011 | 07:16 AM
What fuses are blowing? With that information, we can dig into the wiring and maybe figure out the cause.
Old Sep 7, 2011 | 05:42 PM
The 4x4 fuse keeps blowing when i try to ingadge it
Old Sep 7, 2011 | 06:16 PM
The 4WD fuse (#19 - 20A) supplies power to the +12V motor feed inputs to the TCCM (transfer case control module) and then on out to the encoder motor itself. I would test the wiring from the fuse to the TCCM & from the TCCM out to the encoder motor for shorts to ground. Test it while moving the connectors & harnesses around.
Check out the link below for the schematics:
Please help. 4 wheel drive issue
Manteray
Oct 2, 2011 11:53 AM
razman
Feb 22, 2009 01:57 PM
sfesenko
Nov 30, 2008 08:55 PM
sdm1234
Jan 2, 2008 12:12 AM
tolleyc
Jul 29, 2007 05:57 PM
