4x4 help
Old Jan 10, 2015 | 02:01 PM
welderman85's Avatar
welderman85 is on a distinguished road
Default 4x4 help
I have a 2000 jimmy up until today the 4x4 worked great . I push the button and nothing. i know the could be a bunch of different reasons why its not working. i just kinda want some ideas so i can head into the right direction to fix this. thank you
Old Jan 10, 2015 | 04:15 PM
natem504's Avatar
natem504 is on a distinguished road
Do you have a manual transfer case of Automatic. If it is a automatic transfer it could be the vacuum actuator under the battery having a hole in it and causing the vacuum actuator not to operate. It could be a number of different problems but this is where I would start.
Old Jan 11, 2015 | 06:15 PM
3 button switch on the dash, or a 4 button switch?
Old Jan 11, 2015 | 07:49 PM
Shadow123's Avatar
Shadow123 is on a distinguished road
Just had mine quit when I needed it. I just opened the hood and listened around and hear a vacuum leak. There's a little "T" splitter on top of the engine with a very short 90 degree on it. The 90 was leaking. It helps to move them around a little and you might hear it. I've had the older style and now have the newer style blazer and both times it quit it was a vacuum leak. I just robbed a piece off of a longer hose and fixed it. On the 2001 the push button 4x4 the light was flashing.
Old Jan 12, 2015 | 03:02 AM
LannyL81's Avatar
Suggest checking fuse first. But need more details as to what the 4x4 button lites are doing, how many buttons, does HVAC work 100%.
Old Jan 12, 2015 | 05:23 AM
newguy's Avatar
First thing to do is listen for the transfer case. Open the door push the buttons, you should hear it engage. If it does get underneath and try turning the front wheel driveashaft. If it doesnt turn you know its not the t case and most likely a vacuum problem. Sometimes my light dont light up also, but it still works. Good luck
Manteray
Oct 2, 2011 11:53 AM
razman
Feb 22, 2009 01:57 PM
sfesenko
Nov 30, 2008 08:55 PM
sdm1234
Jan 2, 2008 12:12 AM
tolleyc
Jul 29, 2007 05:57 PM
