95 blazer a/c problem HELP !!!!!
Old Aug 6, 2010 | 10:53 AM
MY1048's Avatar
MY1048 is on a distinguished road
Default 95 blazer a/c problem HELP !!!!!
Does anyone have an answer, My 95 blazer 4.3 has an a/c problem. It works and then it doesn't. a/c works fine then it will just turn off but cold air still comes out the vents the faster you drive the more cold air air you get. The compressor works and cycles the way it should. The system is charged. Anyone have any ideas Thanks Mark
Old Aug 6, 2010 | 06:17 PM
What exactly is turning off? Does the fan stop? Does the air switch outlets?
Old Aug 6, 2010 | 06:47 PM
MY1048's Avatar
Default a/chelp
fan turns off ,no speeds but compressor still working
Old Aug 6, 2010 | 06:49 PM
Does it do this with any fan speed?
Old Aug 7, 2010 | 10:20 AM
R2P's Avatar
R2P
R2P is on a distinguished road
Sounds like a loose wire somewhere in the fan control, the switch could also be going out.
If you have a DMM you could test the switch for continuity and determine what has power and what doesn't when it isn't working, just find out where power should be but isn't and trace that back until you find the problem.
Old Aug 7, 2010 | 11:05 AM
ntjoe's Avatar
ntjoe is an unknown quantity at this point
My Blazer is doing the same thing. The harness that attaches to the blower motor under the hood has an issue and I have to wiggle it from time to time. I haven't taken the time to fix it yet, but that might be a place for you to start.
Old Aug 7, 2010 | 10:55 PM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Could be your relay too. I've found the best tool for fixing this stuff is a good Service Manual with a good step by step troubleshooting guide. You'd be surprised what it can be. It also explains the system in detail with wiring diagrams.
Old Aug 12, 2010 | 12:21 AM
MY1048's Avatar
Thanks for all your help it was a loose wire at the fan
Old Oct 11, 2010 | 03:18 PM
Blazin-95's Avatar
Blazin-95 is on a distinguished road
Default ac control
I have a 95 w/vortek 4.3 & the issue is about the same but not only the a/c it is any of them. I also notice when I hit the brakes it quits blowing. HELP!!!!!
MyBlazerSucks
Jan 5, 2012 12:02 AM
English5
Jul 16, 2010 11:11 AM
soky25
Mar 15, 2010 05:33 PM
Confuused69
Aug 2, 2009 11:53 PM
Daytripper540
Mar 29, 2007 03:54 PM
