95 blazer fuel pressure
Old Nov 25, 2013 | 03:06 PM
nitetrucker's Avatar
nitetrucker is on a distinguished road
Default 95 blazer fuel pressure
So ive been fighting a rich running condition and final did a fuel pressure test today. 62 psi key first on then when pump is done cycling the pressure drops to like 5psi. dammit I got an injector or something leaking
Old Nov 25, 2013 | 03:35 PM
richphotos's Avatar
You will have to narrow it down. Does the engine look like this?
http://memimage.cardomain.com/ride_i...0004_large.jpg
if so, pull off the upper intake plenum, which will give you a good view of the fuel injector.
Look for spots of watching (golden color on the intake) and raw puddled fuel.
If its all black carbon under there, then the leak is elsewhere (most likely the check valve in the fuel pump)
The plenum is pretty easy to get off, take off the air intake, then there are 10 - 10mm bolts, Then there are 2- 8mm bolts that hold the throttle linkage to the plenum, to get the throttle cable undone, open the throttle by hand all the way and the cable will come out (kinda how they are held on for bicycle brakes)
Then there are 2 vac lines on the back of the plenum, a small one on the passenger side, then a large one that connects to the brake booster in the middle.
I have found that the big one that connects to the brake booster is much easier to get off the brake booster and leave it attached to the plenum.
once that is all done, unhook any sensor that is attached to the plenum, MAP, TPS ect. then you should be able to lift it straight up and take it off.
Take photos to post if it will help to determine if there is a leak.
If there is no leak in the plenum, get a new gasket and reinstall.
The bolts should be torqued to 124 inch lbs according to my manual.
Old Nov 26, 2013 | 09:35 PM
you think the check valve woukd cause the constant rich running condition, rough ide and hard starting? I can understand the pressure drop, and yes that image is the motor I have. thx for the info
Old Nov 26, 2013 | 10:22 PM
07nhbpsi's Avatar
07nhbpsi is on a distinguished road
I would say u will find the source of the leak once u pull the upper intake off....:i
Old Dec 3, 2013 | 03:53 PM
finally got a chance to take upper plenum off this last weekend. The FPR and the fuel return line out the spider were leaking like crazy, know wonder it ran so bad. so when I get paid parts will be ordered and it should run like a champ!
Old Dec 3, 2013 | 08:12 PM
07nhbpsi's Avatar
Glad u found the problem!!! I believe rockauto has a good price on the upgraded spider assy!!!
brianroark
Jun 25, 2010 03:14 PM
Spartan66
Jul 11, 2008 02:34 PM
riverjamie
Sep 24, 2007 08:21 PM
aspenpup
Sep 9, 2007 07:11 PM
jlinder
Aug 21, 2005 11:08 AM
