95 blazer OBD1.5 :( need help with paperclip jump
Old May 28, 2019 | 11:01 PM
Spoodini's Avatar
Spoodini is on a distinguished road
Default 95 blazer OBD1.5 :( need help with paperclip jump
I tried searching and get many conflicting reports. It has the the OBD1 sticker in the engine bay but I have a 16 pin port under the dash. My engine light is on and MPG is horrible. I want to get code but do not know how to. I have OBD2 scanners and they obv cannot help. Autozone+O'Reilly says they cant do it either
The 16pin port has the following pins: 2,4,5,9,13,16
I just need to know which two to jump to get the code from the dash. Thanks!
Old May 29, 2019 | 08:05 AM
LesMyer's Avatar
16 pin port is the hybrid system. Can't flash codes. Need capable OBD2 scanner to read it. I think some people have had good luck with at least some of the Actron scanners for the 1995s. Alternatively there is always the GM Tech2. Read this https://www.justanswer.com/chevy/1iz...ht-fender.html
Good luck
Looked it up - it was the Actron CP9145 that is reported to work on your vehicle. It's not made any more, so used is the only way to get one. It is a simple scanner and it is used on both OBD1 and OBD2 vehicles. Make sure you get the adapter cables that you need to hook to your vehicle. I do not have a CP9145 myself, so that is as far as I can get you.
Old May 29, 2019 | 09:58 AM
GeorgeLG's Avatar
I have not used mine in your situation but if you can find one on eBay, its a good scanner and easy to use
George
pfc1
Sep 19, 2016 05:57 PM
Denominator
13
Oct 3, 2012 08:59 PM
dhvhrhmh
Oct 11, 2010 10:51 PM
rastaskater
Mar 12, 2008 06:22 PM
newguy07
Feb 20, 2008 11:56 AM
