95 Blazer rough idle Middletown Ct
#91
What is the part of the motor that gets the most stress?
PS it is not electronic.
#92
i guess its the rings and he has low compression.
#93
My guess is crank bearings or tone rine for the crank sensor
I have the same problem on my 95 but it doesn't throw any codes and its
Very intermintent
Very intermintent
#94
Well replaced the exhaust manifold gaskets, Flange dounuts and Muffler tail pipe to get rid of my exhaust leaks, With no luck problem still exist !!! Gonna try to get a hold of PaulGGoo. My guess to your question would be motor mounts??
#95
do you think it's a bad piston??
#96
Im thinkin we have a similar problem..Maybe it's the color of our trucks Lmao!
#97
Could be I'm trying to get in touch with the guy with the answers!!!
#98
Some suggested that maybe I have bad valve springs what do you think?
#99
Yours could be a weak spring and i'm still thinking mine is a weak lifter..But wouldn't our symptoms show a leak down? I had mine tested several times and i have no leak down.
what a mystery.
what a mystery.
#100
A weak spring could be caught by a leak down test, but probably would not. A weak spring can still provide enough seat pressure to seal, but not enough to keep the valve from floating (being thrown by the rocker arm) which can cause a misfire.
A bad lifter will not be caught by a leak down.
