95 blazer vibration 30 to 40 mph only
Old Aug 2, 2009 | 07:36 PM
matthew116's Avatar
matthew116 is on a distinguished road
Question 95 blazer vibration 30 to 40 mph only
I have a 1995 blazer LT 4x4 I recently replaced the u joints and still have a vibration in the center to rear only on deceleration though checked dif fluid and replaced still vibrating kinda sounds like a semi jake braking or mudding tires ??? any help is grateful thanks in advance
Old Aug 2, 2009 | 08:18 PM
Did you make sure to keep the same orientation of the parts? If the slip yoke is turned 180* to the driveshaft or if the driveshaft is turned 180* to the yoke on the differential, it can cause a vibration. Had this very thing happen on my dad's K2500. I did not take the old u-joints out, just put it back together and dad did not mark anything before taking it apart. Turned the driveshaft 180* to the rear yoke and that did not help. Need to drop the shaft again and twist the slip yoke to the driveshaft.
Old Aug 2, 2009 | 08:26 PM
matthew116's Avatar
will try with fingers crossed my dad is telling me my pinion bearing could be bad ??
don't know the symtoms though
Old Aug 2, 2009 | 09:31 PM
bandidolenny's Avatar
When you changed the fluid did you notice alot of metal flakes in it?
Old Aug 3, 2009 | 06:20 PM
matthew116's Avatar
no metal shavings but it was black as motor oil
blazer2k
Mar 11, 2013 11:42 AM
NVR KNO
Jul 27, 2011 08:50 AM
Barney
Dec 12, 2010 09:09 AM
woodsballr
Apr 19, 2007 12:12 PM
syrblitz19
Jun 17, 2006 09:13 AM
