95 Blazer Water Pump
Old 10-28-2011, 10:07 PM
btmbass's Avatar
btmbass is on a distinguished road
Default 95 Blazer Water Pump
Hey everyone. So I've got a coolant leak somewhere between my radiator and engine right by the fan, it has to be the water pump right? It seems to only leak overnight, while running nothing leaks.
I've replaced water pumps on caprices before and it pretty easy, how hard is it on the blazers?
Old 10-28-2011, 10:08 PM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
Make sure its not the thermostat housing running down.
Remove fan shroud,fan blades,belt etc...should beable to get right to it.
Old 10-28-2011, 10:11 PM
xgiovannix12's Avatar
check your hoses also before heading for the water pump
Old 10-28-2011, 10:16 PM
Thogert's Avatar
Yeah, not too hard. I did it afew months ago. Hardest part was getting the round double ended screws out of the old water pump.
Old 10-28-2011, 10:19 PM
chris015's Avatar
I tell u what...i am pro at waterpumps on 1st gens..
My 1st blazer i had,had over 600k on it..I redid 9 water pumps in 2 months. They would hold for a few,then leak again. to find out the block surface was warped. I stuck a ruler against it and could see light! So i finally fixed it.2 gaskets on 1 side,and 5 on the other,and tightened it as tight as i could possibly get it. didnt leak for 5 months,then i sold it.
Old 10-28-2011, 10:24 PM
lol wow 5 gaskets ? you couldnt seal it with black rtv?
Old 10-28-2011, 10:27 PM
Thogert's Avatar
Oh, and by the way btmbass. My water pump would leak whilst running.
I found this out on a 450 mile trip and while getting gas I came out of the station and saw that my blazer was bleeding! Orange coolent all over the bottom of the truck.
Something to think about.
shesrdy2laff
10-14-2009 12:46 AM
Beckyj636
08-28-2009 05:53 PM
jonesjamesw
07-07-2008 10:28 PM
green75
10-11-2007 08:47 AM
45auto
08-18-2006 03:09 PM
Quick Reply: 95 Blazer Water Pump
