95 coolent temperature sensor location
Old Nov 17, 2010 | 10:35 AM
bommaritomike's Avatar
bommaritomike is on a distinguished road
Default 95 coolent temperature sensor location
hello i have a 1995 blazer with v6 vortec cpi, and i can not find the temperature sensor location anywhere i bought it already just dont know where it is at. i read that there are two one is the switch for the gauge and one is for the computer i got the one for computer so if anyone knows where is located whould greatly appreciate your help.
Old Nov 17, 2010 | 11:08 AM
I believe that you could have two sensors. One for the gauge and one for the PCM/ECU depending on the configuration.
The one for the PCM/ECU should be right near where the upper radiator hose meets the block at the thermostat housing.
The one for the gauges may be in the side of the cylinder head.
Old Nov 17, 2010 | 11:33 AM
mierze's Avatar
mierze is on a distinguished road
ETC for the gauge is on the drivers side head, between the middle and rear spark plugs. youll find two sensors there, the top one is the coolant temp, the lower one is a knock sensor.
Old Nov 17, 2010 | 03:27 PM
Ok found it thx for help. What's the easiest way to take that out? Should I just take the water pump house off and get a extension and ratchet or do I need to take the ac bracket off?
lry040
Apr 15, 2008 06:25 PM
skyblazer
Jun 26, 2007 07:01 AM
eelding
Jun 23, 2007 06:15 PM
eelding
May 10, 2007 09:54 PM
