96 Blazer 4wd Radio Antenna
Old Mar 19, 2009 | 12:38 AM
Beckyj636's Avatar
Beckyj636 is an unknown quantity at this point
Default 96 Blazer 4wd Radio Antenna
I need to replace the radio Antenna how is it routed. I have to change the antenna its self and the cable in the truck.
Thanks
Old Mar 19, 2009 | 11:48 AM
It exits just to the passenger side of the transmission hump. If you remove the passenger side lower dash panel you should be able to see it. You may have to pull back the carpet a bit though.
Once it is in the engine bay, I believe it travels under the HVAC box and into the fender.
Old Mar 19, 2009 | 01:57 PM
Beckyj636's Avatar
Thank you
Old Mar 19, 2009 | 02:14 PM
No problem. Any more questions, just post up!
Old Jan 9, 2010 | 02:02 PM
kiwiblazer's Avatar
I'm needing to replace my antenna now. It's been snapped off.
Looks like I need to remove the fender to get access to pushing the cable back into the footwell.
BUT, in order to hold the new one in place, I need to get behind. How? There's no room.
Looks as if I'll need to remove the fender (passenger) or the inner guard. Any suggestions? Remember too this is RHD but maybe (hopefully) the reverse of LHD.
WTF? The Haynes manual says to remove bumper & hood as well to get the fender off!
Old Feb 24, 2011 | 07:30 PM
mjt's Avatar
mjt
mjt is on a distinguished road
Default Antenna
You can say that again. The service manual says remove the grill and hood and fender to replace the antenna. And I thought the Japanese were bad. GM has some real hackers.
Old Jul 11, 2011 | 11:59 AM
berniescout's Avatar
berniescout is an unknown quantity at this point
for a while now I have had noisey am reception. did some testing today and think I have found the problem. If I remember corectly the ground shield should be grounded at the antenna base (mount on the fender). when I remove the antenna wire connection above the heater / ac box I have an open circuit between ground and the braid. appears the braid is not connected to the antenna base. How do you remove the base from the fender without removing the fender? I may have to sleeve the ant. cable with another piece of braid, which might be easier for me to do and ground it at both ends. any thoughts???
thanks bernie
Old Jul 13, 2011 | 09:48 AM
any thoughts on antenna removal? I can loosen the bracket by removing the two mounting screws, but how do you get the antenna mount out of the finder?
thanks
bernie
Old Jul 14, 2011 | 07:49 AM
mjt's Avatar
mjt
You need to remove the hood and fender. Its ridiculous. I ended up buying a Shark Attack 2 antenna from LoCustom for about $25 and mounted on the rear roof. Works excellent. Its an amplified antenna.
Old Jul 14, 2011 | 10:04 AM
hey, thanks for the info that I did not want to hear!!!! I was leaning that way and hoping for better info. Temporaraly I slipped a piece of braid over the antenna coax cable. The end near the base of the antenna I put a couple of alligator clips over it to hold it tight and hopefully make contact with the base. On the other end I did the same tring to make contact with the shield of the motorola connector. Then I jumper cabled it to the frame. Need to check it with the ohm meter, and see if I made conntact. It did reduce the noise, but did not eliminate it.
If anyone else comes up with another suggestion please post it as I really don't want to remove the fender. Looks like a royal pita just to get at the antenna mounting base.
again thanks,
bernie
irish13tag
Oct 7, 2011 07:53 AM
blazerguy22
Feb 26, 2011 09:57 PM
rastoma
Nov 12, 2009 05:16 PM
elementalnature
May 23, 2009 11:42 PM
johng
Jan 16, 2008 06:08 PM
