96 Blazer fuel problem
Old Jan 21, 2009 | 08:21 PM
  #31
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
Default RE: 96 Blazer fuel problem
I feel funny saying this cause you seem like a good s%@& but....would you stand in the middle of the highway? Why run it sooo low on gas? If your sender is funky, fill up, clear your trip and get a gas re-fill at around 180-200 miles when you can(one 1/2 ish). If you didn't know it this will prolong the life of your fuel pump aside from that fact less condensation can form in the tank resulting in a possible gas line freeze up. Not sure how cold it gets in Sheboygan but I wouldn't want to risk it. After a couple of tank fulls you'll be able to gauge where certain levals of fuel relate to your gauge. Or....what I was going to say is you could replace the tank sending unit but....I know, I know you did that already plus an Airtex pump/module. Now you got me thinking...wonder if that Airtex isn't regulated quite right/same as an ACDelco-based on what you're saying-if you've had this awhile, must be that it reads different than b-4 because of the stall issue but anywho that is easily correctable if.....I think you get it! Good luck and I'm glad the power seat is now working-you probably need a lumbar assembly in the other seat-just tell your passengers that there is no lumbar! Jerry[&o]
Old Jan 21, 2009 | 11:51 PM
  #32
Beckyj636's Avatar
Beckyj636 is an unknown quantity at this point
Jerry I did not intentionally run it that low on the Pontiac I just got in the car and went to work, My folks had the car that morning, ya it was one hell of a surprise to see needle on empty.. but it kept going to the gas station. Thank GOD !.. I guess maybe the ac delco would have been the better pump choice but I was in a money crunch, I will watch the gauge and remember this truck 1/4 means get gas now who knows when I pull the pump back out to put that darn O-Ring on it ( I really knew better then not to put in on in the first place) I will just place an ac delco in instead maybe the sending unit will be more accurate. Oh well new vehicle for me means getting to know it Positives and negatives ))
Old Jan 22, 2009 | 06:07 AM
  #33
I totally understand-in fact still own an 1989 S-10 Blazer me and the wife bought brand new-in fact the last vehicle we bought new. So.....I know about positives and negatives!Jerry
Old Jan 31, 2009 | 02:23 PM
  #34
Beckyj636's Avatar
I have some **** pore luck, today the truck went dead w/ 3/4 tank of gas.. I put some fuel in the throttle body and voom started!! went to the pump disconnected the hoses, turned the key no fuel come out BUT I hear the fuel inside the tank spraying !! Could that clear hose on the pump come off??
I really have no choice to drop the tank@@!!
Old Feb 1, 2009 | 10:03 PM
  #35
Beckyj636's Avatar
yep assumption was right ! the clear hose blew off the plastic housing (top of pump). I just simply bought a BRAND NEW one and did not want to fuss w/ fixing it.. I i got it all together this time w/out beeaking the roll over vent me happy
vansoffthewall53
Sep 2, 2014 09:31 PM
95jblaze
Aug 27, 2011 03:46 PM
spgeid
Dec 23, 2009 03:54 PM
mjd808
Dec 15, 2009 05:41 PM
dgetty
Nov 8, 2009 10:01 AM
