96 Chevy Blazer Wont Start!
Old Jan 24, 2014 | 11:12 PM
Ally-Katt's Avatar
Ally-Katt is on a distinguished road
Exclamation 96 Chevy Blazer Wont Start!
Okay! So I have a 96 Blazer, about a month after I bought this truck, it was kind of chugging almost like it was missing, particularly up hill. It would do its chugging thing for a minute then run just fine. THEN one night my battery in my fob for my viper alarm system died, and the alarm went off and i couldnt shut it off so i disconnected the battery until i could get a new battery for my FOB. Everything was fine, the truck started up just fine, I got to the end of my drive way which is about half of a kilometer, the check engine light came on and it chugged some more then it was just fine. I managed to get about another kilometer down the road and it died. Like completely died. I have checked all the things i could think it would be such as spark plugs/wires, battery, fuel pump/filter, Air cleaner, fuel pressure,fuses, relays, Everything!! I have reset the alarm and my truck wont start!! It turns over, and the motor rotates but it wont catch and fire! I dont know what is wrong with my POS. PLEASE HELP ME!!!!!
Old Jan 25, 2014 | 03:27 PM
burned's Avatar
burned is on a distinguished road
Anytime a engine wont start you need to check for spark and fuel.
Old Jan 27, 2014 | 12:03 PM
Ally-Katt's Avatar
I have checked spark and fuel like I stated in my post.
Old Jan 27, 2014 | 12:17 PM
rockp2's Avatar
Start with a fuel leakdown test. Use a fuel pressure gauge you can get as a loaner at an auto parts store if you don't have one. Hook it up to the test port on the fuel line. Turn the key to the "on" position but do not start your truck. You should hear the fuel pump run for 2 seconds. During that 2 seconds the fuel pressure must read 60-66psi. Once the fuel pump shuts off the pressure should remain above 55psi for 10 minutes. Post your results.
Old Jan 27, 2014 | 12:18 PM
Tajohns34's Avatar
Did you get the code for the Check engine light? Most parts stores will check it for free.
crazycz
Jan 30, 2010 10:47 AM
sharky689
Nov 16, 2008 04:00 AM
chevy66c10
Feb 13, 2008 07:06 PM
jwomack
Feb 7, 2008 03:52 AM
