97 Blazer 4 dr Passenger Side Power Mirror Replacement
Old Jan 28, 2009 | 11:32 AM
crags's Avatar
crags is an unknown quantity at this point
Default 97 Blazer 4 dr Passenger Side Power Mirror Replacement
I have to replace the power mirror on the passenger side of my truck does any one by chance know how this done? How do I go about removing the one that is broken???
Any help appreciated.
Carol
Old Jan 28, 2009 | 12:04 PM
Default RE: 97 Blazer 4 dr Passenger Side Power Mirror Replacement
You have to first remove the inside door panel. There will then be three or so nuts you remove that hold the mirror onto the door frame. You will also probably have an electrical connection to disconnect before fully removing the mirror.
Old Jan 28, 2009 | 12:33 PM
dBsound's Avatar
dBsound is an unknown quantity at this point
Removing your door skin is the hardest part. The mirror itself is easy. Watch for the two hidden bolts, that hold your door handle to the door.
Old Jan 28, 2009 | 12:39 PM
idr's Avatar
idr
idr is an unknown quantity at this point
You know I have a question about the door panels if someone does not mind. Was in there the other day as a matter of fact replacing the mirrors. To the guy with the mirror, it is easy once you remove the door. One screw by the door handle and do not forget to pry out the little keeper the screw screws into and do not loose it. Then you look inside your armrest, you will see a little plastice cap that is narrow and about 3 inches long, gently pry that up and take out those two bolts. The sides have these white plastice things on them that go into the metal frame of the door so pull out the bottom and them pull out on the sides, one at a time then you you have to lift up as the top of the door panel has a lip on it that secures itself in the window track. You will see what to do behind the mirror there
My question is this, how the heck do you actually remove the door panel from the car ? I got it up, can kind of turn it up or down but the actually inside door handle is holding the thing on. Cannot figure how to get that off and the hole for the door handle is not big enough so as to kinda wiggle the pannel off the handle. Thanks guys
Old Jan 28, 2009 | 01:43 PM
dBsound's Avatar
You need a socket on an extension. Or a nutdriver.
upmaine
Jul 9, 2012 12:31 PM
Wexinlo
Apr 6, 2011 11:35 PM
dawnorrhea
Aug 1, 2010 10:38 AM
RCarp48
Feb 26, 2007 05:01 PM
hillbillyinOhio
Jul 12, 2006 04:18 AM
