97 Blazer: 4wd issue while on the highway
My blazer did the same thing, and it ended up being the vacuum switch on the transfer case being bad, $20 part and about 30 minutes of work and BAM, done no more noise
and is really fun to get to. Persistence and an open ended wrench will do the trick. Check to see if there's any fluid in the switch before replacing. Also, the ball on the end of the switch should depress easily and freely. When I replaced mine, the stocker no longer did this.
cant find the vacuum switch on thr transfer case... I do have a 3 button dash switch so there should one... What's the best way to get to it???
Diagram LINK
Is the best I can find at the moment without crawling under my truck and snapping a pic. I got to mine by lying underneath the driver's side, head by the LF tire. Reach up and around the transfer case. It will be on the top right if you're lying how I described. There are three vacuum lines attached to it.
Found the vacuum switch...
Replace it along with the actuator under the battery. 4x4 works as it should again.
On the vacuum switch I removed, the ball was stuck in. This must be such a common thing to go bad the vacuum switch was on the "HELP" rack at the auto store.
I also picked up a for sale sign while I was there!
chriscrm
01-04-2013 01:19 PM
Davidhicks80
07-21-2012 05:29 PM
simplyjessi
01-21-2012 10:10 PM
