97 Low Beam Driver Side Doesn't Work
Old Jan 26, 2011 | 08:29 PM
ChevyFamily's Avatar
ChevyFamily is on a distinguished road
Default 97 Low Beam Driver Side Doesn't Work
This is pretty odd. My 97 Blazer only has one bulb for day time running, low beams, and high beams. The DRL and High beams work fine but the low beams only work on the passenger side. Anyone seen this problem before? I searched through the forums but didn't see anyone with only one side not working.
Old Jan 26, 2011 | 08:33 PM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Probably a bad filament but I'm not that familiar with DRL. How many filaments are in the bulb?
Old Jan 27, 2011 | 12:41 AM
Only a single filament in there. I forgot to say I went and picked up a new bulb and had the same problem with the new one.
Old Jan 27, 2011 | 01:36 AM
Time to check wiring my friend.
Old Jan 27, 2011 | 11:10 AM
Anyone know where the relays are located on a 97?
Old Jan 27, 2011 | 01:13 PM
UberFail's Avatar
UberFail is on a distinguished road
doubt its a relay (would affect both drv n pas side's @ the same time). get out the volt meter and test the connectors on your wiring harness.
As far as DRL's go, they run off your highbeam's so do your hi's even work? i suspect the harness has corroded out or the wires have cracked inside of it.
mamawolf70
Apr 10, 2020 10:44 AM
Mike4x4ing
Jul 6, 2013 01:21 PM
cory30189
Dec 25, 2012 08:12 PM
marine
Jan 28, 2010 07:05 PM
dimmuborgir6nik6
Feb 27, 2008 01:34 PM
