98’ blazer worked fine parked it for ten min start it and drive and nothing but first
Old Sep 27, 2019 | 12:20 AM
Iwillwin's Avatar
Iwillwin is on a distinguished road
Default 98’ blazer worked fine parked it for ten min start it and drive and nothing but first
I brought my son to school I was on my way home stopped at the store turn the truck off turn the truck on and when I went to drive now all of sudden I have nothing but first gear as fast as I could go is 40 miles an hour And that is pretty much maxing out my RPM meter There’s transmission fluid in it so that’s not a problem it is clean all the fluids are fine what happened someone please give me your insight
Old Sep 27, 2019 | 06:01 AM
Do you still have reverse?
Since you state that your speed maxes out at around 40mph, I assume that your speedometer is working which means that your VSS is working. A malfunctioning VSS could cause the transmission to not shift out of 1st gear.
It is possible that the Shift Solenoid B has failed. This can be replaced with only dropping the transmission oil pan. There are a few other things that it could be as well so proper diagnosis should be done to confirm the true problem.
Old Sep 27, 2019 | 11:06 AM
Iwillwin's Avatar
Thank you for your input I greatly appreciate it thank you
Olutech
Jun 5, 2019 07:29 PM
Jcourt2195
May 21, 2014 06:53 PM
NicholasTeal
Jan 24, 2012 10:29 AM
96blazer191k
Jun 22, 2011 12:30 AM
gsmollin
Jan 30, 2010 03:53 PM
