98 blazer, acts up when AC is on
We could drive the truck all day with no problems, then we turn the AC on and sometime after the truck hesitates and spudders, codes p0300 and p0108 kicks in. Last summer I put in new plugs, wires, cap , rotor, coil, module, maf, spider, ecm, distributor, egr, iac and tps. Truck had been running nice and in the past few months she started again, I was pulling my hair until I notice that she acts up only when the AC is on. Help will be highly appreciated. The florida heat is a killer. Thank you guys in advanced.
- Bad MAP sensor
- Leak at MAP sensor rubber gasket
- Engine vacuum leak
- Short in signal wire to PCM
- Short on reference voltage wire from PCM
- Open in ground circuit to MAP
- Worn engine causing low vacuum
- stuck-open EGR Valve
- defective Idle Air Control Motor or dirty IAC port and or dirty IAC motor plunger, which causes a very low or very high engine idle.
Just throwing out a few ideas. Hope it helps to locate the source of the problem.
I clear the codes, turn the ac off and then she gets back to normal
Potential causes of a P0108 code:
- Bad MAP sensor
AutomagicLS1
08-01-2013 04:53 PM
Shaggy
06-13-2010 08:35 AM
