98 blazer key problem
Old Jan 29, 2012 | 01:37 AM
Kyle Wood's Avatar
Kyle Wood is on a distinguished road
Default 98 blazer key problem
So i have no idea whats going on. I have had two keys made at two different places and they will not start my blazer. But they will unlock my doors. Help?
Old Jan 29, 2012 | 06:01 AM
step66's Avatar
Its highly possible that the lock cylinder is worn. Did this problem exist prior to making the new keys? Or,why did you make new keys? Suggestion to all:keep your keychain weight as light as possible to reduce wear on the cylinder. step66
Old Jan 29, 2012 | 07:43 AM
pettyfog's Avatar
Had exactly the same problem. 2 made Found that one worked, other didnt. Both worked doors fine.
Found the one that didnt work, would if pulled it back slightly and jiggled. Yet the two keys lined up side by side were identical. Worn cylinder usually has troubles with the original.
Old Jan 29, 2012 | 12:13 PM
Kyle Wood's Avatar
I recently bought it and only had one key that came with it. I'm going to try playing with it today and jiggiling the key around and see what I can do. And I also might possibly try getting another key made, if you have any other ideas let me know. Ill keep you posted
Old Jan 29, 2012 | 03:12 PM
Kyle Wood's Avatar
ok good news one of the other keys it does work i just need to leave the key out a slight sliver, and a lil jiggle and it will start up thank you !!
Old Jan 29, 2012 | 03:49 PM
step66's Avatar
So the lock cylinder is the culprit-right! Sure seems like it! Let us know! step66
Old Jan 29, 2012 | 05:35 PM
Kyle Wood's Avatar
Sure seems like it to me, Im not going to tar it apart haha, im going to leave it as it is for now. No probblem with the original key, and i got a spare to work so im going to leave it , if you dont mind poke around and look at my other posts to help
changeme20
Oct 24, 2020 02:12 AM
Läyskä
Mar 5, 2012 09:24 AM
tomcat408
Mar 19, 2011 11:32 AM
4x4blazerguy
Apr 10, 2010 08:21 PM
03BlazerLS
Nov 26, 2009 02:40 PM
