98' HVAC control switch module?
Old Nov 22, 2019 | 03:49 PM
toddm's Avatar
toddm is on a distinguished road
Default 98' HVAC control switch module?
Been having some intermittent issues with my HVAC not changing airlfow to all the areas, checked/replaced various vacuum hose, verified the transfer case is okay. All the vacuum connections seem dry, but I still have a hissing at the control switch. So I'm thinking the switch itself has worn out/gone bad.
However the problem appears to be that no one sells a replacement switch for the 98' anymore, the part appears discontinued with GM with no replacement/alternative, I did find a couple listed but they were almost $300. Doorman makes a remanufactured unit but it appears it only fits 99' and newer, and they don't make anything for the 98'
Anyone know if the 99' up will also fit the 98? I hate to take a risk on a used/take out unit when it seems to be such a pervasive issue.
Thanks!
Old Nov 22, 2019 | 06:58 PM
Is it auto or manual temp control?
98+ should all be the same
Check local salvage yards. It's not really a part that goes bad often.
Toby Hanson
Apr 22, 2013 09:10 PM
Toby Hanson
Aug 26, 2012 04:47 AM
Rafiki
Aug 11, 2012 12:33 AM
jdsmall
Oct 8, 2010 08:38 PM
Schm
Dec 14, 2009 10:32 PM
