98 LS instrument cluster PROBLEM
Old May 12, 2007 | 06:53 PM
Russ57's Avatar
Russ57 is an unknown quantity at this point
Default 98 LS instrument cluster PROBLEM
At first gas gage was off ,no problem went by odom/trip meter,then both of those quit working.Got used cluster off of ebay gas gage and temp gagedon't work,trip meter and odometer don't work after starting car,but will work with car not running with ign. switch in on.....pull gage fuse and trip meter and odom...will work with car running....right blinker rate 3x's to fast no burnt out bulbs...went to two dealers both want to replace pod w/o even checking..if old one is bad $350 +$70 to program then $78 an hour to check for shorts,anyone have similar problems?[:-]
Old May 13, 2007 | 09:33 PM
DINO55's Avatar
DINO55 is an unknown quantity at this point
Default RE: 98 LS instrument cluster PROBLEM
Hopefully When you bought your Dash Cluster off Ebay, You made sure it was from a 1998 S10 ONLY, Any other year just wont work correctly.....
Old May 14, 2007 | 01:43 AM
20Blazer00's Avatar
Check all of your ground wires on the truck...there is a main ground on the radiator core under the battery tray mount at the core support imediately under the headlight on the passenger side. Also make sure that all the engine grounds are good. If you have to remove them and make sure that contact area is good...then check all your grounds inside the dashboard area, make sure that all the connectors are tight with the Body Control Module (BCM) and working properly...also if the dealer will ask them for documents on how to program the dash to the computer...the service department service writer might do this for you....
muddyboots
Nov 18, 2013 02:59 PM
car5car
Jul 14, 2012 12:07 PM
n9ktw
Apr 20, 2011 06:58 AM
kgpace
Jul 16, 2009 12:13 PM
Hot Rod
May 13, 2008 01:43 PM
