98 S10 cruise control
Old Aug 15, 2023 | 10:57 AM
jacked_72's Avatar
jacked_72 is on a distinguished road
By the switch, I presume you mean the set button at the end of the turn signal stalk. I'll rig it up so I can see if I'm getting 12 v while the car is in motion, but I've tested it for voltage half a dozen times with the car stationary in the drive way. Even with the car still running after a failed engagement while driving, it has always read battery voltage when the set switch is applied. It will be a good double check to make sure it is doing what it is supposed to while moving. Wiring/connector and grounds appear to be good. If the switch tests good, I may give the module a wack with a hammer and see if it starts to work.
Old Aug 15, 2023 | 11:02 AM
GeorgeLG's Avatar
What you want to do is make sure your familiar with the function when it engages properly then leave the meter hooked up until it won't engage, then see if the switch is at fault.
George
Old Aug 27, 2023 | 05:34 PM
jacked_72's Avatar
I pulled a circuit board from a junk yard cruise control module and it seems to have resolved the issue. The board was an updated part out of a later model, so maybe there were issues with earlier versions.
Old Aug 27, 2023 | 08:25 PM
GeorgeLG's Avatar
Glad you fixed up.
cdtek101
Jun 6, 2021 11:48 AM
liberatorx2
23
Oct 4, 2016 08:48 AM
carpboy
Nov 10, 2010 07:59 PM
Xtreme Blizz
Aug 19, 2007 09:45 PM
burcham
Dec 5, 2006 02:29 AM
