99 Blazer Engine Swap ???
Old Jan 30, 2010 | 02:22 PM
Katmandu's Avatar
Katmandu is on a distinguished road
Thumbs up
Originally Posted by swartlkk
You can use everything from the top of your '99 motor. The only item that really needs to be from the old motor is the lower intake. Provided that the engine is the later 2002 thru end of production, the spider is commonly used as an upgrade for the '96 thru mid-02 so I would use the newer spider. Everything else is up to you. Use the parts that look the best.
Thanks for your help. Much appreciated!
Old Jan 31, 2010 | 09:58 AM
Katmandu's Avatar
Question
I found a 2007 4.3 out of a Sierra 1500.
It's a long block only, so I'll have to reuse the intake/fuel injection and front accessories of my 99.
Other than the above knock sensor issue, is there anything else I need to be aware of ?
Old Feb 28, 2010 | 07:48 PM
Katmandu's Avatar
Thumbs up
I found a low milage (30k miles) 2006 4.3 long block. The only difference between this an my 99 4.3 was the style of knock sensor that was used.
My mechanic simply retapped the 2006's knock sensor boss to accept my 99 style knock sensor.
NO other issues to address!
So if you need an engine for your 99-00 S10 or Blazer, here's an alternative for you!
94BlazerGirl
Aug 28, 2014 06:14 PM
gmoney30
Jul 5, 2010 08:51 PM
SureShooter29
Mar 18, 2010 03:02 PM
Phillips8201
Mar 16, 2010 10:26 AM
gmoney30
Jan 22, 2010 07:07 PM
