99 blazer hard starting when warm
Hey there my blazer has 157k on it and it starts fine when its not ran overnight or 8hrs after it sits but when you start it after the first time it takes 30 seconds or longer to restart you can turn the key back and forth as many times as you want and it don't help it has a new fuel pump can any one help me?
Fuel pressure key on motor off 62lbs running 55lbs any ideas not had a tps code iat code and iat is reading pretty high temp it was 76 outside and iat was 135 and there was a p0300 code and o2 sensor codes and if you take the iat out and blow on it for a lil bit the blazer would start easier
cgrett
11-15-2010 09:08 PM
spunbearing
09-26-2007 05:01 PM
