99 Blazer LS Excessive Noise while moving
Old Sep 24, 2010 | 07:07 AM
Whsperz's Avatar
Whsperz is on a distinguished road
Default 99 Blazer LS Excessive Noise while moving
A friend of mine has a 1999 Chevy Blazer LS that is experiencing a noise that is quite overwhelming. Since he isn't all that mechanically inclined, he came to me (the Jeep guy) and I figured that this would be a good place to ask if anyone had any ideas.
At about 30 mph or faster there is noise (that I first thought was road noise) that over powers the sound of the engine. Even if he lets it coast its an overwhelming hum coming from the front. The tires have less than 500 miles on them and have been balanced. It sounds the same in 2HI and 4HI.
Any suggestions or questions about the rig on where to look or considering would be greatly appreciated. Living on a small island in Alaska with no official mechanics makes it difficult to take it to a shop.
Old Sep 24, 2010 | 09:56 AM
TripleBlackBlazer's Avatar
Does it change in intensity when turning left or right? All fluids up to snuff? What if he puts it in neutral and coasts while at speed?
Old Sep 26, 2010 | 03:11 AM
Whsperz's Avatar
Thanks for the reply. Tested it out today. The intensity does not change when turning. The fluids are good and it still does it in neutral.
Old Sep 26, 2010 | 09:30 AM
knwollen's Avatar
knwollen is on a distinguished road
Does the noise go away when you put it in 4wd? If so the vacuum switch on the transfer case may be bad and it is engaging the actuator cable.
Old Sep 26, 2010 | 01:36 PM
Whsperz's Avatar
Switching between 2HI and 4HI makes no difference.
Old Sep 26, 2010 | 02:45 PM
mykeboy01's Avatar
mykeboy01 is on a distinguished road
Check the water pump
Old Sep 29, 2010 | 04:14 PM
BLOND1WD's Avatar
BLOND1WD is an unknown quantity at this point
I just had my blazer checked for a constant droning that I had assumed was tires. Turns out its pinion bearings in rear making the racket.
arizonablazer
Jul 16, 2014 06:40 PM
Impact
Jun 10, 2011 07:12 PM
zx2guy
Dec 17, 2010 06:43 AM
walleye seeker
Sep 1, 2010 09:52 PM
rudnik
Feb 4, 2010 02:17 PM
