vibration while braking moving forward
Old Dec 16, 2010 | 09:19 PM
zx2guy's Avatar
zx2guy is on a distinguished road
Default vibration while braking moving forward
98 blazer with near 130k. While moving forward at any amount of speed and braking the vehicle will shudder violently in a pulsing manner. The brake pedal itself will shake and push back against your foot with enough force that after a test drive my foot/leg felt fatigued. This only happens going forward, tried 2wd/4wd, while in drive and neutral and it is the same. While in reverse it does not happen at all. The front end has new ball joints, shocks and tie rods, calipers and rotors are just over 2 years old. Under a suggestion I tried unplugging all of the fuses and wires to the ABS but the issue remained. Any help would be appreciated.
Old Dec 16, 2010 | 10:41 PM
oktain's Avatar
Sounds like your front rotors may be warped... Weird how it doesn't do it in reverse though. Did you get the fronts checked? For the pedal to shake violently like that that definitely says brake issue to me though
Old Dec 16, 2010 | 11:14 PM
zx2guy's Avatar
I thought that too, I took it twice as fast in reverse as I could notice it happening going forward and it does not happen at all. Rotors appear great, laid them on a true flat surface and could not find any abnormality.
Old Dec 17, 2010 | 06:43 AM
Are you sure that everything is installed properly? How are the back brakes? Does the vibration feel like it is coming from the front or the rear?
rexazz2
Tires and Wheels
Nov 21, 2013 04:10 PM
1911cdp
Jul 31, 2010 02:00 AM
rudnik
Feb 4, 2010 02:17 PM
ronjer
Apr 22, 2009 06:17 PM
Sarahsmith854
Jul 19, 2007 09:03 PM
