99 Blazer S10 Brake light issues.
Old Jun 22, 2020 | 01:15 PM
jbell's Avatar
jbell is on a distinguished road
Default 99 Blazer S10 Brake light issues.
Ok I have no brake lights on my 99 blazer. Turn signals work hazard lights work I checked all fuses look ok. So I checked the Orange wire down at the foot pedal switch and there is no power to it. What fuse link do I check for continuity to see if the wire itself is bad?
Old Jun 22, 2020 | 05:05 PM
So none of your brake lights work; neither side brake lights nor you center brake lights?
Old Jun 23, 2020 | 12:16 AM
GeorgeLG's Avatar
The power on the orange wire for the stop light switch at the brake pedal come from the Stop LP fuse 20A in the underhood fuse block. There are no fusible links. That fuse gets Always On Power.
George
Old Jun 23, 2020 | 08:51 AM
jbell's Avatar
No brake lights work both side and center do not work. Turn signal and flashers work so know the bulbs are ok.
Old Jun 23, 2020 | 08:53 AM
jbell's Avatar
The stop LP fuse shows good.
Old Jun 23, 2020 | 09:06 AM
jbell's Avatar
Ok guys the stop lp fuse "looked good" but testing it did not so I replaced the fuse now everything is good.
Old Jun 23, 2020 | 09:28 AM
GeorgeLG's Avatar
Glad you found it.
George
Old Jun 24, 2020 | 01:19 PM
Dang. I should have thought of that. I have had fuses that looked good but were broken. I suspect from vibrations. Congrats! Aren't the easy fixes the best?
MrNeedles
Nov 4, 2011 06:10 PM
Kwint
Apr 24, 2011 10:26 PM
jdm2004
Feb 22, 2011 12:30 AM
BlaziNator
Oct 31, 2010 03:23 AM
xunzi
Feb 18, 2008 08:58 PM
