99 Jimmy Wont start
Old 01-20-2016, 08:48 PM
litlmeal's Avatar
litlmeal is on a distinguished road
Originally Posted by Captain Hook
The BCM needs to be programmed to the vehicle it is being used in. Do you have access to a scan tool that will show live, real time data, (not just a code reader)?
I have access to one that will show some live data but not reprogramming
  #62
Old 01-20-2016, 08:49 PM
What brand and model number is the scan tool?
  #63
Old 01-20-2016, 08:55 PM
litlmeal's Avatar
Its a Creader professional 123
  #64
Old 01-20-2016, 09:20 PM
Looks like it should do the job just fine. Plug her in, key on, engine off, and post what you find. Hopefully we can spot something.
  #65
Old 01-21-2016, 04:57 AM
litlmeal's Avatar
Is there something specific you want me to look towards as there is still no codes. And securtiy light is on constant on dash will that cause part of the issue?
  #66
Old 01-21-2016, 01:52 PM
Go to the engine data menu, key on, engine off, and post what you find.
Some scan tools, (not all) will show "Fuel Enable", and list the status as "ON" or "OFF". You might have to look around in the scan tool to find it. With the ignition ON, see what the status is.
  #67
Old 01-21-2016, 03:54 PM
litlmeal's Avatar
I found a few things :
VTD fuel disable-inactive
Cyl 1 thru 6 injector circuit status-fault
MIL circuit staus-fault
And ran some tests and this one failed:$07 data- $0C. Fail
Any clues or does this help?
  #68
Old 01-21-2016, 04:37 PM
"Cyl 1 thru 6 injector circuit status-fault"
Does it give any details about this?
  #69
Old 01-21-2016, 04:42 PM
litlmeal's Avatar
No it doesnt and didnt throw a code just said that when looking thru all the data. I was looking to maybe trade my crp123 in and buy a matco maxme scanner to read a little more in depth
  #70
Old 01-21-2016, 04:55 PM
That might be helpful information anyway. We know at least one injector is working due to the fuel pressure dropped when testing, but there might be others that aren't. At the injector harness connector, there are 6 pink wires, see if all 6 have battery voltage with the key on, engine off. Maybe try wiggling the wires while checking.
Quick Reply: 99 Jimmy Wont start
